Subieaction Posted November 1, 2014 Share Posted November 1, 2014 Hey, evening. I wanted to know if Someone can take a look at this log for me. I am running a Stage 1 from cobb map 91oct. Only mods are a magnaflow exhaust and exedy comp clutch. I see that there is a large amount of knock around 3rpm. Thanks, Chrisdatalog29.csv Link to comment Share on other sites More sharing options...
serx7 Posted November 3, 2014 Share Posted November 3, 2014 Your pull starts around 3400 rpm but the learned corrections are being applied b/n 4k and 5.5k rpm, some of which are multicount (ie: ECU heard knock, pulled -1.4 deg, still heard knock, pulled another -1.4 deg, still heard knock, pulled another -1.4 deg, etc). Do a brief idle log including AF Learning #1A, B, C, D, to see what your long term fuel trims look like. If none of the trims are pegged max (15 I believe) and otherwise look decent (+/- 5% preferred, +/- 10% still sort of OK but IMO not so OK), you might be able to rule out a leak that's causing you to run lean. IIRC the Cobb OTS maps allow the D trim to also be applied to open loop/WOT so you don't want to see the D trim too negative (lean). If you feel like experimenting, reset the ECU, use the AP to pull -3 to -5 deg global timing, warm up the car fully, drive it around for a while to let the fuel trims settle in again (the higher trims can take more than a day depending on your driving style/conditions), then repeat the 3k+ rpm pull/s, and see if you still see the knock show up in the logs. If the previously seen knock situation doesn't clear up much/at all after pulling -3 to -5 deg global timing, it could be a mechanical cause (loose heat shield, drivetrain noise etc). Link to comment Share on other sites More sharing options...
Subieaction Posted November 4, 2014 Author Share Posted November 4, 2014 Logging it now will upload when finished. I do have a lose heat shield after I let go of the gas still in gear that rattles. Link to comment Share on other sites More sharing options...
serx7 Posted November 4, 2014 Share Posted November 4, 2014 Ah. Fix the loose heat shield before you go through the effort of doing more WOT logs. Hopefully that's the sole cause of your logged knock. Link to comment Share on other sites More sharing options...
mikeydrives1 Posted November 4, 2014 Share Posted November 4, 2014 Thats a fair amount of fine learned knock there for just 14-15lbs of boost pressure on a stock turbo. A loose heatshield in my tuning experiences has and will cause the sensor to start picking up false noise in the middle of pulls, depending how bad it is rattling. Link to comment Share on other sites More sharing options...
Subieaction Posted November 4, 2014 Author Share Posted November 4, 2014 Will tighten it this weekend when I go to change the spark plugs. Yes there is a bit of rattle when I let go of the pedal but don't always notice it when I am engaging the pedal. The 15lb boost is at the peak for my stage 1 tune. Link to comment Share on other sites More sharing options...
