tredmor Posted October 28, 2014 Share Posted October 28, 2014 Hello, I just ordered a new 2015 Legacy. The wheels are 17x7, 5x114 bolt pattern, and 55 offset. Tires are 225/55/17. I would like to add rims off of a 2015 WRX. They are 17x8, 5x114 bolt pattern, and 55 offset. My question is will the 225/55/17 fit and will the 17x8 fit (no interference with suspension or shocks)? Thanks. Link to comment Share on other sites More sharing options...
Ellesedil Posted October 28, 2014 Share Posted October 28, 2014 You're probably going to have to do this research yourself since so few people have experience with the 2015 Legacy. Here's a head start: http://www.willtheyfit.com/index.php?width=225&aspect=55&diameter=17&wheelwidth=7&offset=55&width2=225&aspect2=55&diameter2=17&wheelwidth2=8&offset2=55#content The tires should fit on those wheels just fine. The wheels will probably fit, but no one can be 100% sure without test-fitting them on a 2015. Link to comment Share on other sites More sharing options...
GTEASER Posted October 29, 2014 Share Posted October 29, 2014 ^^What he said. Tires will be fine on those wheels. As long as you think you can go 1/2" (or 13mm) closer to both the struts and the wheel wells, you should be fine. See the calculation per the link that Ellesedil provided. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
tredmor Posted October 29, 2014 Author Share Posted October 29, 2014 Thank you both for the info. Sounds like it should work, but I should take a measurement first. Link to comment Share on other sites More sharing options...
bearcat Posted October 8, 2015 Share Posted October 8, 2015 Anyone try rims this size? I've found some decent priced wheel and tire sets of the 2015 WRX wheels I've been thinking about picking up as a summer wheel. Link to comment Share on other sites More sharing options...
Simonsez Posted October 8, 2015 Share Posted October 8, 2015 Yes the will fit and work well 100% sure Link to comment Share on other sites More sharing options...
