HeavilyMedicated Posted September 9, 2005 Share Posted September 9, 2005 Hi all! I own.. ok my wife owns.. Uh, I paid for and do the maintenance on a 2000 Subaru Legacy Wagon (95,000 miles, auto trans). Last fall it developed a bit of road noise from the rear. The development took place over about 3 months and has not gotten noticeably worse since. I thought it was the rear struts, and since we were not noticing any major ride issues, I let it slid until yesterday. I replaced the struts, they where in fair shape, and took it for a drive. My wife and I both thought the noise was less, but maybe by about 1/4, this was obviously not the source of the road noise. After we got home I took off the rear drum and looked at the brakes, nothing seemed wrong or worn. Nothing my DIY eye could see anyhow. I’m thinking bearings maybe? Or something in the rear drive… The sound comes in about 20 mph and gets slightly but progressively louder until about 45, after that it does not get substantially louder. Which is not to say the sound you hear at 45 is much louder then the sound you hear at 20, its not, but the road noise at 15 vs. 25 is quite substantial. At 15 it is quiet, and 25 it is quite a noise. The sound is quite mid-low in effect, like road noise, seems to come from each side equally (or from the middle), and is not affected by acceleration or stopping of any kind (hard, soft, hard brake, downshift braking). It is constant once it starts. Any ideas? Thoughts? Any replies are appreciated, thanks for reading this. Link to comment Share on other sites More sharing options...
AreEyeSeeKay Posted September 9, 2005 Share Posted September 9, 2005 I think you are right on with the wheel bearings. I recently rode in a car which needed them replaced and the sound was like you describe. Link to comment Share on other sites More sharing options...
mwiener2 Posted September 9, 2005 Share Posted September 9, 2005 moved to older legacy My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
low_suby_wagon Posted September 9, 2005 Share Posted September 9, 2005 First check those wheel bearings. Inner and outer. The only thing is that you are saying it is coming from the "middle" that makes me think drive axle issues. Start with the obvious and cheap way, the bearings, and then check drive axle componets. They should be changed anyhow and with that many miles it could be bad bearings on both sides. Link to comment Share on other sites More sharing options...
jlk97legacygt Posted October 7, 2005 Share Posted October 7, 2005 how is the condition of the rear tire's? just thought i would ask, since it is a lot eaier to fo rotate the tires and see if the noise changes. Link to comment Share on other sites More sharing options...
HeavilyMedicated Posted October 7, 2005 Author Share Posted October 7, 2005 Problem solved, rear bearings! But thanks for all the replies Link to comment Share on other sites More sharing options...
