Streetlegal Posted October 20, 2014 Share Posted October 20, 2014 Picking up a Spec B this week and seems to have a small issue. The security light is always on solid and not blinking. However, the car runs and drives fine with no other issues. The PO said he took it to a Subaru dealership and they could not figure out why it was on. I've looked around on here, Nasioc, and ShopKey Pro (basically the guide dealers use when they fix cars. I have access through work) and I can't seem to figure out why it would be on. A few threads I have seen that talk about the security light the people are also having their car shut off right away. In the ShopKey manual it says to test for valet mode or if the security system is on. It said if the security system is off the light will be on and vice versa. Anyone have an idea of what this could be from? Possible electrical short somewhere since there are no other symptoms? Link to comment Share on other sites More sharing options...
apexi Posted October 21, 2014 Share Posted October 21, 2014 Dumb question but I have to ask out of curiosity.. What does your key look like? Does it have a chrome key ring or plain black plastic? I'm sure you or Subaru would've caught this, but I'm wondering if you're using the valet key? Link to comment Share on other sites More sharing options...
Streetlegal Posted October 21, 2014 Author Share Posted October 21, 2014 Dumb question but I have to ask out of curiosity.. What does your key look like? Does it have a chrome key ring or plain black plastic? I'm sure you or Subaru would've caught this, but I'm wondering if you're using the valet key? I am not familiar with subarus, at least the small details like that, I will look and find out. Wouldn't the car drive different in valet mode if I was using the valet key? Link to comment Share on other sites More sharing options...
apexi Posted October 21, 2014 Share Posted October 21, 2014 On the cars I've owned in the past, the only difference with the Valet key is that it can't open the glove box and trunk, it looks like the Legacy is the same way. *Post #12 in the link below is interesting as well. Since you just got the car recently, I could see a dealer trying to use the wrong key in the ignition by accident. The link below says trying to use the wrong key can set the light off, and it will eventually go away over time. Which makes sense, since you are still able to start the car and drive just fine even with the security light illuminated. From what I've read if the system is really unhappy, the car either won't run at all, or will run for a few seconds then shut off. http://www.subaruoutback.org/forums/109-gen-3-2005-2009/76770-security-light-always-2.html Link to comment Share on other sites More sharing options...
Streetlegal Posted October 22, 2014 Author Share Posted October 22, 2014 This is a picture of the keys. From the chart below it doesnt look like a valet key. Hopefully the light just eventually goes off after awhile like it did in that other thread. Link to comment Share on other sites More sharing options...
apexi Posted October 22, 2014 Share Posted October 22, 2014 You're right, from what I understand that looks like one of the regular master or submaster keys, and not a valet key. Hopefully the light does go off on its own. Link to comment Share on other sites More sharing options...
Richard_Mtl Posted December 28, 2016 Share Posted December 28, 2016 Did you ever get this sorted? The security light is on in my car since this morning. Not clear on why or how to reset. Link to comment Share on other sites More sharing options...
