bochuck Posted October 5, 2014 Share Posted October 5, 2014 Can somebody help me with the Mishimoto radiator part number for 05 LGT 5EAT? Checked a bunch of sites but don't see a part number. Also saw that it required an aftermarket trans cooler. Just want to make sure I buy the correct one. VF-52 and all associated bits tuned by Tuning Alliance. Link to comment Share on other sites More sharing options...
bochuck Posted October 6, 2014 Author Share Posted October 6, 2014 ttt VF-52 and all associated bits tuned by Tuning Alliance. Link to comment Share on other sites More sharing options...
bochuck Posted October 6, 2014 Author Share Posted October 6, 2014 Ok. Found a few vague threads here that hint at the MMRAD-STI-08 as the radiator to get. Now, question is, what size trans cooler? VF-52 and all associated bits tuned by Tuning Alliance. Link to comment Share on other sites More sharing options...
apexi Posted October 6, 2014 Share Posted October 6, 2014 This thread appears to have some good information. http://legacygt.com/forums/showthread.php/properly-plumb-your-5eat-transmission-cooler-221643.html?p=4743891#post4743891 If you do not have an OEM Radiator (not pictured) then your best bet is to use a bypass thermostat and air cooler. This can be a bit more difficult to dial in for year-round stability if you live in a climate that has hot summers and very cold winters. You will not have the radiator to pull down hot ATF temps or pull up cold ATF temps. Over-cooling becomes very easy without a radiator, even if you have a bypass thermostat (though the bypass thermostat does help a lot). If you have a non-OEM radiator, then it's probably worth your while to buy a temperature gauge. That said, many other cars come from the factory with an air cooler and a bypass thermostat, without a radiator heat exchanger provision. The difference is those coolers are sized to provide adequate cooling from -30F to +130F while being driven normally. Link to comment Share on other sites More sharing options...
