Nachowang Posted September 8, 2005 Share Posted September 8, 2005 This is my 1st time buying aftermarket rims so please bare with me. I'm very close to buying a set of enkei rims 17x7 5-100 38 on www.tires.com, im searching under 2004 Subby WRX for my 05 LGT, one of the options they add was $45 extra for the "wheel installation kit" aka lugs. My question is: Will I need these lugs for the new rims or will my stock ones do, and also do these lugs for the 04 WRX even fit an 05's LGT? Thank you in advance Link to comment Share on other sites More sharing options...
Nachowang Posted September 8, 2005 Author Share Posted September 8, 2005 They had a 800 number so I called it and said lug size is the same. So im guessing I can use my stock ones. BUT, they told that in their system it says minimum of 41mm offset for a 17x7 so now im getting conflicting stories. So right now im feeling like this: Link to comment Share on other sites More sharing options...
Xenonk Posted September 8, 2005 Share Posted September 8, 2005 This is my 1st time buying aftermarket rims so please bare with me. I'm very close to buying a set of enkei rims 17x7 5-100 38 on www.tires.com, im searching under 2004 Subby WRX for my 05 LGT, one of the options they add was $45 extra for the "wheel installation kit" aka lugs. My question is: Will I need these lugs for the new rims or will my stock ones do, and also do these lugs for the 04 WRX even fit an 05's LGT? Thank you in advance Even some lugs provided by such companies are still too big for the socket to fit in the lug hole because the "tuner" lugs they gave you are still too big (usually you might need a thin-walled socket to get to it). Since you are buying aftermarket wheels, it's best to save that money from the lug kit and get yourself the McGard SplineDrive Tuner Lugs which are very well designed and have the least amount of hassles based on fitment, seating, and security. The lug sizes you need are a set of 20 12mm x 1.25mm pitch lugs. Keefe Link to comment Share on other sites More sharing options...
Xenonk Posted September 8, 2005 Share Posted September 8, 2005 They had a 800 number so I called it and said lug size is the same. So im guessing I can use my stock ones. BUT, they told that in their system it says minimum of 41mm offset for a 17x7 so now im getting conflicting stories. So right now im feeling like this: If you go by my offset wheel FAQ, you won't have any more feelings. From my experience with Enkei wheels, the stock lugs probably wont fit in the lug holes, you should look into buying some quality tuner lugs as I mentioned in the 3rd post. Keefe Link to comment Share on other sites More sharing options...
Nachowang Posted September 8, 2005 Author Share Posted September 8, 2005 Thanks again Xenonk, I can always count on you. -> The wheel lugs you mentioned, do you know of any place or website where I can find them? Link to comment Share on other sites More sharing options...
sandwood Posted September 8, 2005 Share Posted September 8, 2005 http://subydude.com/osc/index.php?cPath=92_132&osCsid=867eec23a85c7887a684fffc3a87afd3 getting out of the legacy game Link to comment Share on other sites More sharing options...
Mui01 Posted July 29, 2006 Share Posted July 29, 2006 Even some lugs provided by such companies are still too big for the socket to fit in the lug hole because the "tuner" lugs they gave you are still too big (usually you might need a thin-walled socket to get to it). Since you are buying aftermarket wheels, it's best to save that money from the lug kit and get yourself the McGard SplineDrive Tuner Lugs which are very well designed and have the least amount of hassles based on fitment, seating, and security. The lug sizes you need are a set of 20 12mm x 1.25mm pitch lugs. +1, after reading this, got myself a set and they are awsome! It even work on my aftermarket spare wheel. Thanks Link to comment Share on other sites More sharing options...
