sneeky Posted October 4, 2014 Share Posted October 4, 2014 I'm losing coolant, but I am not seeing any noticeable leaks or puddles. When I drive the vehicle is not overheating & I am hearing a wierd grinding noise near the dash. Any thoughts? Link to comment Share on other sites More sharing options...
MrTris Posted October 5, 2014 Share Posted October 5, 2014 Check the coolant galley drain plug for signs of crusty/leaking coolant from the block. This is the port that connects to the oil cooler, which is what the oil filter is screwed on to. Take a look at the connections in that area; those little elbows carry coolant from the block, to the oil cooler, and the to the coolant crossover pipe, which, depending on where you live, should be inspected for signs of rust and/or corrosion and replaced, if necessary. Link to comment Share on other sites More sharing options...
