christopher Posted September 9, 2014 Share Posted September 9, 2014 My cruise control was fully functional until about a month ago. The light on the button on the dash still lights, and it shows on the cluster that the cruise is on, but when I try to set my speed it just doesn't input, so it coasts instead of cruising. I also found pieces of what seems to be a white clip in the carpet, not sure if that has anything to do with it... It's a 1998 if that means anything. Thanks in advance. Link to comment Share on other sites More sharing options...
christopher Posted September 10, 2014 Author Share Posted September 10, 2014 bump, anyone have any knowledge? Link to comment Share on other sites More sharing options...
johnegg Posted September 10, 2014 Share Posted September 10, 2014 does your horn work? pic of the white clip? is it part of an electrical connector? do you have any ''warning'' lights on, like a check engine light? fuses? causes of cruise failure, fuse? bad speed sensor bad clock spring vac line? maybe a cruise throttle cable issue under the hood. Link to comment Share on other sites More sharing options...
christopher Posted September 11, 2014 Author Share Posted September 11, 2014 Horn works. No warning lights on. Sorry, no pic of the clip, got tossed out a while ago :/ Link to comment Share on other sites More sharing options...
christopher Posted September 15, 2014 Author Share Posted September 15, 2014 bump anyone with any knowledge, please? Link to comment Share on other sites More sharing options...
96legacyls Posted September 16, 2014 Share Posted September 16, 2014 could be as easy as a vacuum line or might need new switch or clock spring reel. but i do have complete cruise set up for sale and i know it works. 2 actually one from my 96 legacy and one from my buddys 98 legacy Link to comment Share on other sites More sharing options...
