ssbtech Posted September 7, 2014 Share Posted September 7, 2014 Here's a log I took today. Not sure if I've selected the right parameters (we need a "what to log" sticky...) I'm concerned about the FBKC. It's similar to what was happening when I had three exhaust valves replaced due to burning a year and a half ago. Thoughts? Thanks romraiderlog_20140907_123708.csv Link to comment Share on other sites More sharing options...
serx7 Posted September 8, 2014 Share Posted September 8, 2014 Def not a fan of those FBKC #'s, esp the increasing timing pull as RPM climbs. My math might be wrong, but your peak target boost is listed as 194.65 kPA absolute, which at sea level would be about 13.5 psi. Your MRP sea-level values seem to indicate you're a few psi below target boost -- but if you're not at/close to sea level, you might want to use the regular Manifold Relative Pressure parameter instead. Maybe you have a leak that's throwing off your fuel trims? Can you get a Live View, or do a quick log of AF Learning #1 A, B, C, D? Although your AF Correction #1 goes to 0 right around 3k rpm so it looks like no fuel adjustments are being applied after 3k rpm... Link to comment Share on other sites More sharing options...
ssbtech Posted September 8, 2014 Author Share Posted September 8, 2014 I should state that it's the latest factory tune available for the car, so peak boost is only what, 12.5 for the Outback XT? Thanks. Link to comment Share on other sites More sharing options...
serx7 Posted September 9, 2014 Share Posted September 9, 2014 I d/l the 2005 USDM OBXT stock map (whose CAL ID matches mine) from the Romraider site, and pulled it into RomRaider's ECU Editor. Looks like the stock boost targets are 13.54 psi at 2400-3600rpm, tapering to 10.25 psi at 6400rpm (8.51 psi at 6800 rpm). Link to comment Share on other sites More sharing options...
RallyMachine Posted September 9, 2014 Share Posted September 9, 2014 I'm guessing if he's logging in kPa he probably doesn't have the US model lol... Link to comment Share on other sites More sharing options...
ssbtech Posted September 9, 2014 Author Share Posted September 9, 2014 I'm guessing if he's logging in kPa he probably doesn't have the US model lol... You're right, Canadian Model I just don't know what buttons to push Link to comment Share on other sites More sharing options...
ssbtech Posted September 9, 2014 Author Share Posted September 9, 2014 Looks like I'm running A2WC522N for the ROM. Yes, it's for an 05 Legacy... on my Outback... Link to comment Share on other sites More sharing options...
ssbtech Posted September 9, 2014 Author Share Posted September 9, 2014 Can I download that colourful chart right from my car using RR ECU Editor? Link to comment Share on other sites More sharing options...
ssbtech Posted September 9, 2014 Author Share Posted September 9, 2014 I was also under the impression that the engine won't necessarily hit the target boost levels, the targets are just there to allow the engine to make the maximum boost that it can. Link to comment Share on other sites More sharing options...
serx7 Posted September 9, 2014 Share Posted September 9, 2014 I'm guessing if he's logging in kPa he probably doesn't have the US model lol... sh-t you're right I thought that to myself and apparently forgot about it during the 30 sec search for the stock ROMs over on RomRaider. Looks like I'm running A2WC522N for the ROM. Yes, it's for an 05 Legacy... on my Outback... so it's still running a USDM calibration. my OBXT runs A2WC510N, also a USDM calibration file. Can I download that colourful chart right from my car using RR ECU Editor? If you open the .hex in RR ECU Editor, and navigate to the Boost Control - Target -> Target Boost A, you'll see the current boost targets. It's been a while since I've done stuff in Open Source, but you should be able pull down your car's actual calibration using ECUFlash. I believe you mentioned that your car is running stock calibration, so you should be able to just d/l the stock ROM from here, and open that in RR ECU Editor. http://www.romraider.com/forum/viewtopic.php?f=35&t=7591&sid=35374936d220f7eceb35baaf155c1750 The targets appear to be the same as what I posted above for the other CAL ID, 13.54 psi peak. I was also under the impression that the engine won't necessarily hit the target boost levels, the targets are just there to allow the engine to make the maximum boost that it can. In my experience you should still be able to hit or get real close to target, esp at transition, through peak torque and at least a bit beyond that. One of the problems w/ setting unrealistically high boost targets, esp at lower RPM, is that turbodynamics integral typically winds up and often leads to overshoot around transition. Link to comment Share on other sites More sharing options...
ssbtech Posted September 9, 2014 Author Share Posted September 9, 2014 It certainly doesn't feel like I'm hitting maximum boost at 2500RPM, that's for sure. My recent LV shows 1.9 for column 1, 1.00 for column 2, -3.4 for column 3 and -6.9 for column 4 which is kinda useless with the stock rear O2 sensor anyway. I did correct a boost leak at the manifold inlet hose a couple of months ago and that helped the 1 and 2 columns a lot. Link to comment Share on other sites More sharing options...
serx7 Posted September 9, 2014 Share Posted September 9, 2014 It certainly doesn't feel like I'm hitting maximum boost at 2500RPM, that's for sure. My recent LV shows 1.9 for column 1, 1.00 for column 2, -3.4 for column 3 and -6.9 for column 4 which is kinda useless with the stock rear O2 sensor anyway. I did correct a boost leak at the manifold inlet hose a couple of months ago and that helped the 1 and 2 columns a lot. The -3.4 and -6.9 are probably due to a leak (although -3.4 is still within acceptable range). AFAIK the D range value (-6.9) gets applied to open loop which might be causing a lean condition under boost, which in turn might be inducing knock. Link to comment Share on other sites More sharing options...
ssbtech Posted September 16, 2014 Author Share Posted September 16, 2014 A few months back I did a leak test and found the short hose between the IC and TB was leaking. I pulled out the rubber rings on either end of it, cleaned up the hose and reinstalled, sans rings. Today I did another test and I think I hear the leaking from that hose again. Other than re-seating it and tightening up the clamps a bit more, is there anything else I should check around there? Thanks. Link to comment Share on other sites More sharing options...
ssbtech Posted September 17, 2014 Author Share Posted September 17, 2014 Ok, I've pulled off the IC, TB Hose and cleaned up the bit of oil that was around it. Re-installed everything and it's still leaking from around there somewhere. Any more ideas? Link to comment Share on other sites More sharing options...
