Nachowang Posted September 7, 2005 Share Posted September 7, 2005 I've checked xenonk's sticky post and I did a search of rims/tires to fit on a 04 STI/WRX so im 99% certain that this will fit the LGT, but could someone fill in that 1% for me before I spend all this money? TIA! Will these fit? 17X7 5-100 Offset: 40 and 17X7 5-100 Offset: 38 Both running on 225/45/17 tires Thanks again Link to comment Share on other sites More sharing options...
Xenonk Posted September 7, 2005 Share Posted September 7, 2005 http://legacygt.com/forums/showthread.php?t=4426 The thread said it's ok for that offset. Keefe Link to comment Share on other sites More sharing options...
Nachowang Posted September 8, 2005 Author Share Posted September 8, 2005 Thanks Xenonk! So I understand that the lower the offset is, the further the wheels will stick out? Link to comment Share on other sites More sharing options...
Xenonk Posted September 8, 2005 Share Posted September 8, 2005 Thanks Xenonk! So I understand that the lower the offset is, the further the wheels will stick out? in a sense 'yes' so long as you are comparing the same wheel width. "?" Example: A 17x8 +25mm offset will look like a 17x7 +0mm if you look from the fender side.. so the extra 1" width from the 8" wheel will be added towards the shock side of the wheel. Keefe Link to comment Share on other sites More sharing options...
