b18c_ej8 Posted August 16, 2014 Share Posted August 16, 2014 Anyone have access to Directechs or similar that can provide a wiring breakdown for a 2013 Legacy? I'm looking specifically for headlight wiring at the BIU, either the positive or ground side (but ground is preferred). I found a post on a 2010 that says headlight - is blue/green at the BIU, but I can't seem to find a blue/green on my '13. Thanks! Link to comment Share on other sites More sharing options...
nstg8r Posted August 17, 2014 Share Posted August 17, 2014 Anyone have access to Directechs or similar that can provide a wiring breakdown for a 2013 Legacy? I'm looking specifically for headlight wiring at the BIU, either the positive or ground side (but ground is preferred). I found a post on a 2010 that says headlight - is blue/green at the BIU, but I can't seem to find a blue/green on my '13. Thanks! All the grounds from the low beams are engine grounds. On the +12V side, the wire at the BIU that controls the low beam relay is blue with green stripe and is connected at A27 & B25. 24. Headlight System.pdf Link to comment Share on other sites More sharing options...
