finse Posted August 9, 2014 Share Posted August 9, 2014 Hey guys. I have a few items I want out of my garage. I'm really not interested in shipping anything, so this is for you guys in/around Denver. DW Modified Stock 850CC Side Feed Injectors - Had these on my car for 20K or so. I had them cleaned and tested Dec 13'. At that time they were in spec. I removed them due to weird AFR issues at idle. I'd recommend getting retested if you buy them. SOLD! Sidefeed fuel rails - Replaced the rubber hoses in '12. $50 Front Sway - Stock front LGT 54K (06 Spec B) $50 Rear Sway - 20mm Subaru OEM JDM 45K (pic is with 19mm Craftsman wrench, I don't have a 20mm) $75 Stock airbox and tubes - Used for 35K - $50 VF40 Heatsheild - $5 08 Legacy L stereo (manual controls) - $15 06 LGT Turbo coolant tank with cap 54K - $40 06 LGT Catted up-pipe 35K - $20 06 STi Non-catted up-pipe, heatsheild is loose, flexi-joint is of unknown condition - $20 Link to comment Share on other sites More sharing options...
finse Posted August 9, 2014 Author Share Posted August 9, 2014 Whiteline KCA399 - not on the car long, 4-8K, but there are signs of wear - $20 Link to comment Share on other sites More sharing options...
finse Posted August 12, 2014 Author Share Posted August 12, 2014 Bump.. Seriously, no interest? Not even in the 20mm RSB? Link to comment Share on other sites More sharing options...
SSpeed Posted August 12, 2014 Share Posted August 12, 2014 I'll take the injectors! Link to comment Share on other sites More sharing options...
finse Posted August 13, 2014 Author Share Posted August 13, 2014 I'll take the injectors! Injectors pending to SSpeed... Link to comment Share on other sites More sharing options...
finse Posted August 15, 2014 Author Share Posted August 15, 2014 Anyone else interested in the other parts here? Looking to clean my garage out this weekend. I'll be visiting the scrap yard sunday... Link to comment Share on other sites More sharing options...
finse Posted August 19, 2014 Author Share Posted August 19, 2014 Injectors are sold. Best offer on the rest of the stuff, still have that 20mm JDM rear sway...... Link to comment Share on other sites More sharing options...
bronconia Posted August 19, 2014 Share Posted August 19, 2014 Any way to get a fitment check for the sway bar on a 5th gen? Cause I'm interested! Link to comment Share on other sites More sharing options...
finse Posted August 19, 2014 Author Share Posted August 19, 2014 Any way to get a fitment check for the sway bar on a 5th gen? Cause I'm interested! I doubt its going to fit correctly. Otherwise I would imagine the aftermarket sways for the 4th gen would show compatibility for the 5th. At least at rallysportdirect, they do not. Link to comment Share on other sites More sharing options...
bronconia Posted August 19, 2014 Share Posted August 19, 2014 Gotcha. I'll try and do a little research, but I think you're right! Thanks anyway Link to comment Share on other sites More sharing options...
lingling1337 Posted August 19, 2014 Share Posted August 19, 2014 good deal if you need lca bushings id buy those instead of stock replacements. Link to comment Share on other sites More sharing options...
