Dangerzone3 Posted July 28, 2014 Share Posted July 28, 2014 Hey guys, I'm looking to get rear hubs for my legacy to convert my brakes from drums to discs. I found an impreza gc8 parts car with reasonable condition parts. I was just wondering if the rear hubs from a gc8 impreza will fit on my 97 legacy? Thanks in advance. Link to comment Share on other sites More sharing options...
williamfinucane Posted July 28, 2014 Share Posted July 28, 2014 http://legacygt.com/forums/showthread.php/diy-rear-drum-disc-conversion-143569.html I think so. Under materials required it looks like your setup will work. Hopefuly someone can comfirm. I'm going to be doing this very shortly Link to comment Share on other sites More sharing options...
Dangerzone3 Posted July 28, 2014 Author Share Posted July 28, 2014 From the looks of the thread, one of the people used a 2000 RS. That would make the car a first gen. However, they said they were using 04 wrx hubs. Not too sure which one they used and if it will fit. I'm guessing that they should fit. If anybody could give a clear answer, that would be great. Link to comment Share on other sites More sharing options...
johnegg Posted July 29, 2014 Share Posted July 29, 2014 I found an impreza gc8 parts this does not mena anythingf to me, what year and model?? in the 90s, all rear spindle / hub / knuckle assemblies for the legacy and the impreza are the same and will interchange, EXCEPT some have abs and some do not. just make sure you get the one you need. actually, if you get the ones WITH abs, it will fit both. so find a parts yard with suabrus and harvest the parts you need. Link to comment Share on other sites More sharing options...
Dangerzone3 Posted July 29, 2014 Author Share Posted July 29, 2014 The ad doesn't say a year or model. GC is referring to it being a first gen impreza. So the years can be worked out. Also, my car doesn't have abs, so that's good to hear that it will fit both. Link to comment Share on other sites More sharing options...
