Sclantz Posted July 27, 2014 Share Posted July 27, 2014 I have a 2005 LGT and my turn signal in my mirror does not work and the chrome on the inside is peeling. How do I disassemble and fix it or do I have to buy a new assembly? Link to comment Share on other sites More sharing options...
Sclantz Posted July 28, 2014 Author Share Posted July 28, 2014 Pic Link to comment Share on other sites More sharing options...
JJr Posted July 28, 2014 Share Posted July 28, 2014 Parts are expensive, Just find a used working one ( whole mirror assembly, I did $65.00) swap your the skull cap for the correct color. GL Link to comment Share on other sites More sharing options...
Sclantz Posted July 31, 2014 Author Share Posted July 31, 2014 Thanks for the info. How do you remove the skullcap is my next question? I tried but I'm afraid I will break it and can't quite figure it out Link to comment Share on other sites More sharing options...
JJr Posted August 1, 2014 Share Posted August 1, 2014 I removed the skull cap with the entire mirror assembly off the car, I know there are DIY's on removing the door-panel ( it might be in a replacing the speakers thread), removing the door panel was scary, you need to pop it off and use more force than you think. GL Link to comment Share on other sites More sharing options...
