sunny5280 Posted July 16, 2014 Share Posted July 16, 2014 Anyone have any suggestions on cleaning seats? Mine are in relatively good shape but I know with 177K miles on the clock they've likely absorbed their share of dirt and grime over the years. I'm seeking a simple, low cost way to clean the seats. Anyone have any suggestions? Ideally the same solution will also work on the floor carpet (again not in too bad of shape but I suspect they could use a good cleaning too). Link to comment Share on other sites More sharing options...
Dangerzone3 Posted July 19, 2014 Share Posted July 19, 2014 If you want best results, steam cleaning is the way to go. However, to keep costs down you'll have to rent one. It's not worth it to buy one for the one job. Link to comment Share on other sites More sharing options...
johnegg Posted July 20, 2014 Share Posted July 20, 2014 the rear bottom seat of my 95 lego sedan was so dirty, it must have had about 2 gals. of cola poured into it. i removed it and sprayed it with the hose. i wanted to spray it until the water ran clear, but i got tired . it did however improve it's condition. the rear bottoms on the 95 - 99 sedans (and maybe the seat backs) are one large piece of foam with fabric over it. almost like a sponge . i'm not sure i would take the same approach with the front seats or wagon rear seats. but if they are really bad why not. you just have to let them dry completely before you re-install them. Link to comment Share on other sites More sharing options...
sunny5280 Posted July 21, 2014 Author Share Posted July 21, 2014 My neighbor has a steam cleaner that she uses to clean her house. I'm going to give that a try and see how it goes. Link to comment Share on other sites More sharing options...
Matt Walter Posted July 21, 2014 Share Posted July 21, 2014 i've had good luck cleaning up seats by taking the covers off the foam and putting them in the washer, lol. might go to a laundromat if you don't want to kill your wife's machines though! Link to comment Share on other sites More sharing options...
sunny5280 Posted July 21, 2014 Author Share Posted July 21, 2014 That sounds like a great idea (along with going to the laundromat). Are the covers easy to remove and re-install? Link to comment Share on other sites More sharing options...
Matt Walter Posted July 21, 2014 Share Posted July 21, 2014 i had my seats out of the car a couple weeks ago and they looked like they'd be pretty easy to pull off. my experience with that was with a set of seats for a camaro, which looked like they went on about the same way. Link to comment Share on other sites More sharing options...
