T_Altland27 Posted July 8, 2014 Share Posted July 8, 2014 Ok so I'm looking at getting new rims and just need some guidance on if it will work or not I'm not all that good figuring out back spacing and offsets but I'm undecided between the assetta garas by sparco which are 48mm offset with a 6.06" backspacing and the other rims are the edr9 by enkei the offset for those are 45mm by 5.71" backspacing I tried the calculated thing for these but just could understand it can anyone help me out here and let me know if these will fit my 09 legacy 2.5i both are 5-100 bolt pattern Link to comment Share on other sites More sharing options...
kirshnerd Posted July 8, 2014 Share Posted July 8, 2014 Diameter? Width? Tire size? Suspension? And on top of all that there is a thread specific to these questions: http://legacygt.com/forums/forumdisplay.php/wheels-tires-43.html Read the sickies, and search. Assuming you're sticking to the 17-18" and 7-8" width, and normal fitting tires, any wheels in the +50's down to +40's offsets are safe on stock suspension. Link to comment Share on other sites More sharing options...
T_Altland27 Posted July 8, 2014 Author Share Posted July 8, 2014 17,7.5, stock suspension and like I said in op I did read other post and used the offset calculated but I couldn't understand it so that's why I asked Link to comment Share on other sites More sharing options...
