GeorgeB Posted September 3, 2005 Share Posted September 3, 2005 does anyone know if i can fit this in a legacy 2.5i audio system ? PIONEER High SPL band pass subwoofer TS-WX205 20cm Band pass Subwoofer (280x248x446 mm) 250 W (peak) 100 W (rms) 20cm IMPP Composite Cone woofer Large dual port band pass design for kicking and powerful bass 18 liter carpeted wooden enclosure Heat resistant 4-layer voice coil Large diameter Conex damper Auto ON/OFF overload protector Gold-plated screw terminal Nominal input power: 100W 35-200 Hz, 107dB in car (1W/1m), Max S.PL. 129dB in car (1W/1m) ALPINE – Power amplifier MRP T130 Amplifier Type Dual Channel With Bass Boost Bridgable Max. output (peak) 2 x 90 W Power Output RMS at 2 Ohms 65 W x 2 Power Output RMS at 4 Ohms 50 W x 2 Frequency Response 10 Hz - 50000 Hz Low - Pass Frequency 80 Hz - 80 Hz Signal to Noise Ratio 100 dB Bass Boost Frequency 50 Hz THD at Rated RMS Power .08 % Dimensions Width 9 in. / Depth 6.75 in. / Height 2.25 in. Input Voltage 11 volt MOSFET amp tks Link to comment Share on other sites More sharing options...
iguanamafia Posted September 3, 2005 Share Posted September 3, 2005 You can do it!!! http://legacygt.com/forums/showthread.php?t=12608 Link to comment Share on other sites More sharing options...
GeorgeB Posted September 4, 2005 Author Share Posted September 4, 2005 thanks much apriciated, sorry for the stupid topic i'm sorry i didn't search enough Link to comment Share on other sites More sharing options...
