medfordhotrodguy Posted July 2, 2014 Share Posted July 2, 2014 I have a 98 LGTw 187k on the clock, my cats are starting to smell and are pretty rusted. I'm looking to see what others have done: replaced with an OEM direct fit cat (Walker or Magnaflow), had a custom setup made, or just throw them away (I can't do this 1)? Include part #'s if you can. Thanks Jeff Link to comment Share on other sites More sharing options...
johnegg Posted July 5, 2014 Share Posted July 5, 2014 until they fail completely, rust though, fail an emissions test, i would leave them alone. i have never heard of an after market cat that works as well or lasts as long and the suabru factory cat. if you need to replace, i would look for a private seller who has used subaru cats for sale. unless you can afford new suabru cats. subaru cats usually last the life of the car. although i just had to replace mine on my 98 outback, but it went into salt water at a boat ramp, and they rusted out. i have also had to replace the ECU, brakes and the entire exhaust. Link to comment Share on other sites More sharing options...
diesel2wd Posted July 6, 2014 Share Posted July 6, 2014 I am also interested in an answer to this question but I have my own issue. the used car guy I bought my brighton wagon from had someone come in one night and cut off the cats from a bunch of his vehicles. my car was one of them, I've had it almost 3 years, NEVER getting rid of it until the shells rots from around drivetrain. but before he sold it to me, he had an aftermarket one put on. it smells horrible. getting a CEL once in awhile for an o2 sensor. replaced both o2 sensors, fuel filter, air filter. I WANT the boxer rumble. also my header is about due for replacement. have around $300 right now. I can weld in stuff myself just need to know what to look for. Link to comment Share on other sites More sharing options...
johnegg Posted July 7, 2014 Share Posted July 7, 2014 if you convert a spark plug anti-fouler into a spacer, you can run without a cat. the rear sensor just checks to see if the cat is working. if you use a spacer to move it out of the exhaust stream, you do not need cats. i think one guy even passed an emissions sniffer test with no cats. but i would not count on that. the front o2 MUST be very high quality, subaru or better. a cheap o2 sensor on the front can cause a CEL. the rear can be cheap. Link to comment Share on other sites More sharing options...
