firehawk618 Posted July 2, 2014 Share Posted July 2, 2014 I know this could be done but didn't have much luck searching for the info's. I was thinking about trying to use my AEM UEGO output and running it to an UN-used input on my ecu so I can datalog my wideband without having to plug in a serial cable in addition to my Tactrix cable. Anyone here been successful with this? My biggest hurdle would be configuring romraider to re-lable whatever input and what formula to use with said input to get it to display AFR's vs voltage. I do believe the AEM has the serial output "which I use now successfully via serial cable" and a 0-5V output which is the one I figured would be easiest to tie into the ecu. Any good advise is greatly appreciated! Thank you. EDIT: I really don't think I have a single ECU input that I'm not using now except the exhaust temp sensor but I am pretty certain that will not work since it's a resistance based input. I was considering deleting my TGV's in the near future or is there lower hanging fruit that could be used for this purpose...... 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
heiche Posted July 3, 2014 Share Posted July 3, 2014 I would vote for connecting the analog output to a TGV input (assuming that you've deleted your TGVs). There's some info in this thread. BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
firehawk618 Posted July 3, 2014 Author Share Posted July 3, 2014 Great link thank you! I knew I wasn't the first Subaru person to try this. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
heiche Posted July 3, 2014 Share Posted July 3, 2014 you're welcome. please let us know how it goes. BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
