Gbrown Posted June 27, 2014 Share Posted June 27, 2014 Hello all, My 1995 subaru readiness monitors (C, O, and E) reset and start the tests all over everytime I start the car. Catalytic convertor was replaced in 2009. Not that many miles since. What am I missing? Thanks G Link to comment Share on other sites More sharing options...
johnegg Posted June 27, 2014 Share Posted June 27, 2014 it is a quirk in the software. the same is true for the 96MY. but there is an official ''allowance'' for the 96 subaru because if it when it comes to emissions testing. Link to comment Share on other sites More sharing options...
Gbrown Posted June 27, 2014 Author Share Posted June 27, 2014 What about the 1995 legacy? (that's what I have) Link to comment Share on other sites More sharing options...
johnegg Posted June 27, 2014 Share Posted June 27, 2014 it's the same software as 96. but no one knows about the 95 readiness issue because the 95 was not required to be obd2. so 95s are not tested the same way as 96. because almost all other 95 car makes are odb1, and the issue never comes up because you cannot plug in to them. did you fail a test? tell the guy the 95 is not required to be tested. he may be doing just because it has a port. Link to comment Share on other sites More sharing options...
Gbrown Posted June 27, 2014 Author Share Posted June 27, 2014 Thanks! I haven't gone for the test yet, it hasn't failed the last 2, it just seems like I use to get green on my scanner. Good info, I'll be sure and tell them. Gbrown Link to comment Share on other sites More sharing options...
