datdookie Posted June 24, 2014 Share Posted June 24, 2014 So my car seems to be slow in accelerating. Car: 95 Subaru Legacy L Wagon, Manual. Engine: 96 ej22 (single port) MSD Ignition coil. New spark plug wires & plugs. Slightly used K&N air filter. Looks to be new knock sensor. CEL: P0500.(that's the only one) Super high-flow cat with adaptor (old cat)h UEL headers. So I just got this swapped in after my timing belt tensioner bolt got loose (stripped out bracket hole) from my hybrid and bent my valves. Needed and quick and easy fix so I got this ej22 for cheap and swapped it in. The only issue im having with it is that its hard accelerate and it feels like something is holding it back.Took it on the highway once and it was tough to get to 60.Gas mileage could be better. My original ej22 wasn't this slow any ideas what it could be?. Link to comment Share on other sites More sharing options...
Drakien Posted June 25, 2014 Share Posted June 25, 2014 P0500 throws your car into limp mode. That is why it is sluggish. p0500- Vehicle Speed Sensor Malfunction Reset the ECU, unplug the battery, etc. If the code comes back. Replace the sensor. Link to comment Share on other sites More sharing options...
datdookie Posted June 26, 2014 Author Share Posted June 26, 2014 P0500 throws your car into limp mode. That is why it is sluggish. p0500- Vehicle Speed Sensor Malfunction Reset the ECU, unplug the battery, etc. If the code comes back. Replace the sensor. Thanks for the reply. Going to do this asap and see if anything happens. Link to comment Share on other sites More sharing options...
datdookie Posted June 28, 2014 Author Share Posted June 28, 2014 Yep so that didn't do the job. I smell fuel. I think it might be the cat. Going to see if someone has spare I can test out Link to comment Share on other sites More sharing options...
johnegg Posted June 28, 2014 Share Posted June 28, 2014 check the knock sensor. a bad sensor will make your car very sluggish, it retards the timing to a ''safe'', no knock setting.. and if not installed properly even new ones can go bad. clean the block surface, angle it correctly, do not over torque. i use a little dielectric grease on mine for good contact. it is not the cat. they usually do not go bad unless you have driven it for a long time with a blinking CEL. i could be a dirty throttle body or IAC. Link to comment Share on other sites More sharing options...
