xt2005bonbon Posted June 17, 2014 Share Posted June 17, 2014 I've just done some logging to one of my cars (stage 2+) and noticed that the Intake OCV L/R are both stuck at 9.41% either in cruising, idling, and during a 3rd gear pull. Also noticed that the Intake VVT Advance Angle L/R differ by 3-5 degrees consistently except at idle. Did some searching on the web but not much to be found. What do you guys think? Link to comment Share on other sites More sharing options...
heiche Posted June 17, 2014 Share Posted June 17, 2014 any codes or other symptoms? BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 17, 2014 Author Share Posted June 17, 2014 no. no code. Idling appears fine to me. I am actually in the process of tuning the car (tuner's doing it, not me via open source). So while I was logging, I noticed these values which is strange. I wonder if the OCVs are dirty/stuck and need cleaning. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 17, 2014 Author Share Posted June 17, 2014 Just in case, can the OCVs be swapped without having to drain the oil? I would assume so.. Link to comment Share on other sites More sharing options...
ERLoft Posted June 17, 2014 Share Posted June 17, 2014 You should be able to do that. They're at the top of the oil loop, so if you let the car sit overnight, you shouldn't have much up top. I'd still place a rag under each OCV for removal of course. You'll probably get a little bit coming out, but not much. 2013 █S4 - Glacier White - DSG - B&O - Tech Package - Sports Diff - Napa - RS4 Grille - Stasis Exhaust - APR Intake - KW Variant 1 - Stern Control Arms - CR-15 - Stasis RSB - Moog Endlinks - PC Hyper Black Peelers - Deval Front Lip - ECS Rear Diffuser - Carbon Imports Ducktail - ECS Mirror Caps - Relak Paddle Extensions - Autostyle Floor Mats - LED Interior - V1 - Blackvue DR900s - [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 17, 2014 Author Share Posted June 17, 2014 thanks ERLoft Link to comment Share on other sites More sharing options...
RallyMachine Posted June 18, 2014 Share Posted June 18, 2014 Yeah they can be swapped out without changing oil. Just have a paper towel read when you pull them out... No biggie. Link to comment Share on other sites More sharing options...
