JayInVA Posted June 11, 2014 Share Posted June 11, 2014 Title is pretty self explanatory I think. Just got my subie back after having the short block and most of the front end (pulleys, belts, idlers, water pump, etc) replaced. I drove it about 25 miles before getting a steady CEL with blinking cruise control light. The problem is, I can't pull the codes! The OBD2 scanner won't connect. I tried my cheapo bluetooth code reader first but then tried 2 other readers at different AAP stores. I checked and I don't believe the fuse is blown. All of the cigarette lighters work and my bluetooth reader lights up when plugged up so I know it's getting power. It just won't actually connect? Any ideas? Link to comment Share on other sites More sharing options...
Gex Posted June 12, 2014 Share Posted June 12, 2014 Take it back to the shop who did the work? Link to comment Share on other sites More sharing options...
JayInVA Posted June 12, 2014 Author Share Posted June 12, 2014 Yeah that's the next step (tomorrow or Friday if I get the chance). Just wanted to pull the code myself to get a general idea of what I'm dealing with. Link to comment Share on other sites More sharing options...
RallyMachine Posted June 12, 2014 Share Posted June 12, 2014 My guess is probably a system too lean code which would be indicative of a vaccum leak... Link to comment Share on other sites More sharing options...
Xplosivo1 Posted June 12, 2014 Share Posted June 12, 2014 My guess is probably a system too lean code which would be indicative of a vaccum leak... +1 on the vacuum leak, although I don't think that has anything to do with the OBD not connecting. Link to comment Share on other sites More sharing options...
