careercadaver Posted June 11, 2014 Share Posted June 11, 2014 Picked up a set of JDM spats and was considering rattle canning them as I have done in the past. However, this time around I have the SWP (37J) tri-coat paint. I know NAPA typically color matches paint and wondered if anyone had decent luck with these products matching up. I'm likely going to a body shop for these but wanted to weigh options. If you could include pictures of product and results that would be more than helpful as well Link to comment Share on other sites More sharing options...
kirshnerd Posted June 11, 2014 Share Posted June 11, 2014 I've had very mixed results using Napa color code matched paint. First project worth noting I was repainting some WRB side skirts to match the lower gold/grey of my OBS. Got a can mixed, wasnt anywhere close wet. Decided to paint them anyways, let them cure and cleared them, still nowhere close. It looked like brown compared to beige. Went back and verified the codes, used the color code reader tool which came up with a different color code but with the exact same mix numbers. We mixed that color and the paint came out the same. I ended up going elsewhere to get a completely custom color mixed by a pro using the original code as a guide for where to start. My second and very opposite experience was with the upper Metallic Blue Pearl color on my OBS (looks almost black in overcast or night, blue metallic-ish in sun). I was getting a can mixed at Napa figuring it cant be worse than the previous color I tried. I was repainting a JDM grill and color matching some corner markers. Painted all the parts and cleared them. Let them dry and cure, and they came out perfect. Amazing match. Napa was great at returning and refunding for the paint that didnt match, but obviously primer, adhesion promoter and clear were all wasted. Worth a try in my books. Painting them twice can be a hassle but you're likely still going to be under the cost of getting them painted professionally. I'd recommend using adhesion promoter for spats/side skirts, along with a good 2K gloss clear. Link to comment Share on other sites More sharing options...
Eliott Posted June 11, 2014 Share Posted June 11, 2014 Painted a trunk lip with a sherman williams automotive rattle can, came out good enough. Matches pretty good. Can cost $28. Link to comment Share on other sites More sharing options...
careercadaver Posted June 11, 2014 Author Share Posted June 11, 2014 Painted a trunk lip with a sherman williams automotive rattle can, came out good enough. Matches pretty good. Can cost $28. Would you mind posting pics? Link to comment Share on other sites More sharing options...
Eliott Posted June 11, 2014 Share Posted June 11, 2014 I haven't installed it yet, but I'll try to get some to show similarities. Link to comment Share on other sites More sharing options...
GTEASER Posted June 11, 2014 Share Posted June 11, 2014 Find an auto body supply shop near you, they can set you up. It's more expensive but you get a better quality paint and probably a better match. I too have SWP and I was considering doing this for some parts. My local auto body supply shop wants $80 and it will come in 2 cans for the 3 stage paint, base coat and pearl/clear. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
careercadaver Posted June 12, 2014 Author Share Posted June 12, 2014 I have a local shop. Just used to doing this kinda stuff myself and wanted to weigh the option, it's likely I will have them professionally done...just wanted to see if anyone had had decent results...especially with SWP. Link to comment Share on other sites More sharing options...
SBT Posted August 27, 2014 Share Posted August 27, 2014 Moved to technical forums (from Vendor News). - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
careercadaver Posted August 27, 2014 Author Share Posted August 27, 2014 Thank you sir! Link to comment Share on other sites More sharing options...
careercadaver Posted September 10, 2014 Author Share Posted September 10, 2014 ...any input here? Link to comment Share on other sites More sharing options...
Eliott Posted September 10, 2014 Share Posted September 10, 2014 Totally forgot about this thread. My bad, here's a pic. Link to comment Share on other sites More sharing options...
