hudson787 Posted June 7, 2014 Share Posted June 7, 2014 I am wondering if I will need to roll my fenders? I plan on lowering my LGT about a 1 and 1/2 inches or so and want 18X8.75 rims with either 25 or 35 offset with 225/40/18 tires anybody have that size rim on a lowered LGT and if so any rubbing problems? Thanks. Link to comment Share on other sites More sharing options...
RallyMachine Posted June 7, 2014 Share Posted June 7, 2014 With that much offset yes unless your drop is really conservative. I'm running 18x8.5 +44 and I NEEDED my rears rolled. Fronts weren't as bad but when I was low I needed it. Link to comment Share on other sites More sharing options...
hudson787 Posted June 7, 2014 Author Share Posted June 7, 2014 How low was your car? Link to comment Share on other sites More sharing options...
evildriver Posted June 7, 2014 Share Posted June 7, 2014 this thread may help you a bit... Link to comment Share on other sites More sharing options...
hudson787 Posted June 7, 2014 Author Share Posted June 7, 2014 Thanks. Is that post fitment guide saying those are the guides if your car is lowered 2" or stock height do you know? Link to comment Share on other sites More sharing options...
evildriver Posted June 7, 2014 Share Posted June 7, 2014 i believe those are general assumptions, dropped or not. i'm no wheel & tire guru, but i think you'll be hard pressed to fit a 25mm offset without massive rolling and maybe pulling on that size wheel. i recall seeing 35mm with some rolling. if no one else more knowledgeable chimes in i'd recommend reading through that thread. i'm sure someone has tried or asked what you are. Link to comment Share on other sites More sharing options...
hudson787 Posted June 7, 2014 Author Share Posted June 7, 2014 I have read the thread and it helps but still not sure. Thanks for the help though. Link to comment Share on other sites More sharing options...
SpecBFan Posted June 7, 2014 Share Posted June 7, 2014 I'm going to go ahead and say you will have to roll them. I have 18x8 38 offset with 235/40/18 tires. I have progress springs that drop it F1.3/R1 and I needed to roll my rears. I rolled both at the time to allow for a more aggressive drop later. Front http://img.tapatalk.com/d/14/06/07/etuja5eb.jpg Rearhttp://img.tapatalk.com/d/14/06/07/sugu9ysu.jpg Sent from a controlling box in my pocket Link to comment Share on other sites More sharing options...
