candellstick Posted May 31, 2014 Share Posted May 31, 2014 I have an 09 Legacy 2.5 52,700 mi, at a sustained speed at and above 35-40mph, I hear a whirring sound coming from the trans. At acceleration or deceleration, sound disappears. Any ideas? Thanks! Link to comment Share on other sites More sharing options...
Manchito Posted June 1, 2014 Share Posted June 1, 2014 I have the same problem on my 2.5i , i hear a noise coming from under the car , more in the back and its happening only when going between 50-60 kmh , if i go over or under that speed it stop , it also stop when i dont have my feet on the gas . I talked with my dealer about this , and they told me they dont believe its the transmission itself , but more a problem on the driveshaft or the rear diff. Ill have to look at this soon. Link to comment Share on other sites More sharing options...
Okayer2570 Posted June 1, 2014 Share Posted June 1, 2014 Sounds like the difs are going. Get them flushed. And fresh fluids and gaskets see if that changes the noise. Sent from my SAMSUNG-SM-N900A using Tapatalk Link to comment Share on other sites More sharing options...
theflystyle Posted June 1, 2014 Share Posted June 1, 2014 Are you sure its coming from the trans? Link to comment Share on other sites More sharing options...
Okayer2570 Posted June 1, 2014 Share Posted June 1, 2014 The front dif is by the transmission. Could be that. Sent from my SAMSUNG-SM-N900A using Tapatalk Link to comment Share on other sites More sharing options...
candellstick Posted June 5, 2014 Author Share Posted June 5, 2014 It's hard to get a handle on exactly where it's coming from, but a friend of mine suggested possibly a wheel bearing to some degree. Link to comment Share on other sites More sharing options...
