bochuck Posted May 23, 2014 Share Posted May 23, 2014 Okay. I removed my aftermarket springs and struts and replaced them with the stock springs and struts. No disassembly. My stock springs and struts are complete assemblies. Remove and install project. Now my rear feels like the top strut mounts are bad. Can this be caused by installing the assemblies backwards? The rears appear to be installable either way since only two top studs and the through bolt in the control arm on the bottom. Can someone shed some light? VF-52 and all associated bits tuned by Tuning Alliance. Link to comment Share on other sites More sharing options...
bochuck Posted May 24, 2014 Author Share Posted May 24, 2014 anyone? VF-52 and all associated bits tuned by Tuning Alliance. Link to comment Share on other sites More sharing options...
ras06LGT Posted May 25, 2014 Share Posted May 25, 2014 The rear shocks can be installed in either direction. Did you double-check bolt torques to make sure nothing worked itself loose? Link to comment Share on other sites More sharing options...
