Monkey805 Posted August 10, 2014 Author Share Posted August 10, 2014 similar headaches. http://legacygt.com/forums/showthread.php/emergency-timing-belt-help-1998-brighton-2-2-l-ej22e-228705p2.html His car at least stays on, mine just dies after 6 seconds and if i give it throttle it dies faster. Link to comment Share on other sites More sharing options...
johnegg Posted August 11, 2014 Share Posted August 11, 2014 yes, his runs now, but for a while it started and died. it died faster if he gave it gas. look for the large vac line that runs to the IAC, it is under the plastic intake plenum, it is easy to miss because it attaches on the very bottom. you left it un-done. connect the hose and restart the car. while you are at it, check ALL the hose and wire connections. Link to comment Share on other sites More sharing options...
