Riptide Posted May 20, 2014 Share Posted May 20, 2014 Guys the plastic part of my trunk lid got nailed by hail. How does this come apart? Is it easy to pull off the lid? http://i.imgur.com/kI4k064.jpg Sent from my iPhone using Tapatwat Link to comment Share on other sites More sharing options...
nouse4aname Posted May 20, 2014 Share Posted May 20, 2014 Yeah just held on with clips if I recall. Walkthrough on install backup cam has removal steps. Actually think the inner liner has to come off to get access to some bolts too. Link to comment Share on other sites More sharing options...
Riptide Posted May 20, 2014 Author Share Posted May 20, 2014 Darn. Having trouble finding the walkthrough. Tried the search engine. WTH Link to comment Share on other sites More sharing options...
apexi Posted May 20, 2014 Share Posted May 20, 2014 The FSM make it sound like you do everything from outside the car, but it might be easier to remove the liner to pinch the plastic pop-it's out. I've never removed this piece myself so I'm not sure. I do know that I prefer to push pop-it's out from the inside whenever possible. This thread has more pictures too http://legacygt.com/forums/showthread.php/anyone-know-remove-trim-strip-above-rear-license-plate-sedan-56627.html Link to comment Share on other sites More sharing options...
Riptide Posted May 20, 2014 Author Share Posted May 20, 2014 That helps thanks. Looks like it should be fairly easy to get off there. Link to comment Share on other sites More sharing options...
Nrw Posted May 20, 2014 Share Posted May 20, 2014 Remove the plate, there should be a couple bolts visible remove those. Then it is just held in via clips. They will probably be stiff since these cars are old now. Link to comment Share on other sites More sharing options...
Riptide Posted May 20, 2014 Author Share Posted May 20, 2014 No adhesives? Sent from my iPhone using Tapatwat Link to comment Share on other sites More sharing options...
Nrw Posted May 20, 2014 Share Posted May 20, 2014 Not that I remember Link to comment Share on other sites More sharing options...
fullmonte77 Posted May 21, 2014 Share Posted May 21, 2014 No adhesive. Just take the bolts off behind the plate and then just pull it off. Very easy to do. Link to comment Share on other sites More sharing options...
