The_Josh Posted May 15, 2014 Share Posted May 15, 2014 I just installed new struts and shocks plus the 1" subtle solution spacers. I also installed the White line Camber bolt kit. From what I understood that was all that was needed to have a good alignment after the 1" lift. I brought my car down to the alignment shop and they couldn't bring the toe in enough to be within spec. This isn't too good since I'm leaving Monday to go on a 2500 mile road trip to Seattle. That's also not enough time to correct it or order some adjustable links. The alignment shop said I needed the rear most link to be adjustable more than what it is now so he can correct toe. What do you guys think? It seems to drive perfectly fine around town and on the freeway locally. I think I'll order the rear rear lateral links from Megan racing but they definably won't come before I plan on leaving for my trip. Here is the attached alignment specs http://img.tapatalk.com/d/14/05/15/2unyma2e.jpg Sent from my Nexus 5 using Tapatalk Link to comment Share on other sites More sharing options...
garage1217 Posted May 20, 2014 Share Posted May 20, 2014 I just did a 3/4 lift with rear king springs. Heading to alignment today or tomorrow and will let you know what goes on and if I have the issue as well. Link to comment Share on other sites More sharing options...
garage1217 Posted May 21, 2014 Share Posted May 21, 2014 Well nothing I could assist with. My xt aligned just fine yesterday with a 3/4 lift and rear king springs (further lifting the rear a bit) My guess would be a torn bushing or something along those lines to be that far out. Link to comment Share on other sites More sharing options...
