Denunzio36 Posted May 5, 2014 Share Posted May 5, 2014 Need some help here folks. I'm replacing the ball joints on my 2000 Legacy GT, and after FINALLY getting them out, I'm not sure if the housing in the knuckle is good. Based on the design of the ball joint housing on the knuckle (pinch design), isn't there supposed to be a protruding ring on the inside of the ball joint hole in the knuckle? The ball joint has a groove around the base, which I'd assume mates with a ring in the hole. Well, after I removed mine, the walls on the ball joint hole are 100% flush... No protruding ring that mates with the ball joint. My question is... Is this normal? Do I need new knuckles?! Link to comment Share on other sites More sharing options...
Denunzio36 Posted May 5, 2014 Author Share Posted May 5, 2014 Here's some other pics: http://img.tapatalk.com/d/14/05/06/zapa8u6y.jpghttp://img.tapatalk.com/d/14/05/06/bu7u6agu.jpg Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
987687 Posted May 6, 2014 Share Posted May 6, 2014 Looks pretty normal to me. Clean it up with some sandpaper. Use anti-seize so maybe it doesn't stick so much next time (it'll still stick...), and torque it down. The pinch bolt goes in the groove of the balljoint keeping it from falling out. It also squeezes the housing closed around the joint to hold it in place. Link to comment Share on other sites More sharing options...
Denunzio36 Posted May 6, 2014 Author Share Posted May 6, 2014 Good point about the bolt locking in the groove. Thanks! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
