krot84 Posted May 5, 2014 Share Posted May 5, 2014 Hey guys I keep forgetting, what's the flow direction of the cabin filter? Is it from bottom up or the other way around? Thanks Link to comment Share on other sites More sharing options...
apexi Posted May 5, 2014 Share Posted May 5, 2014 I believe the dirty air flows down through the cabin air filter. Every time I remove the filter to inspect or change it, the dirt and debris is sitting on top of the filter element. Link to comment Share on other sites More sharing options...
krot84 Posted May 6, 2014 Author Share Posted May 6, 2014 Thanks, after i thinks about it, it was a pretty dumb question for me. The thing is that i ordered an after market carbon filter and it didn't have the marker of air flow on it. one side was dark and the other white as you can see on the photos, so i didn't know which side of the filter should be up. Link to comment Share on other sites More sharing options...
KRM Posted May 6, 2014 Share Posted May 6, 2014 just got the fram carbon filter for mine. and it was the darker side facing down sir. Link to comment Share on other sites More sharing options...
apexi Posted May 6, 2014 Share Posted May 6, 2014 I too use the Fram and I was pretty sure that the darker side faced down, but was going to double check later. Thanks for confirming and saving me some time KRM. Link to comment Share on other sites More sharing options...
KRM Posted May 6, 2014 Share Posted May 6, 2014 Not a problem at all. I also noticed that the flat edge of the fram fit into these little tabs around the inside of the tray to make it stay in place. So make sure you run your fingers around the edges of it after fitting in the filter. Link to comment Share on other sites More sharing options...
krot84 Posted May 7, 2014 Author Share Posted May 7, 2014 Could someone please explain me the difference of the position on the carbon filter? What could get wrong if i put the filter not as the manufacturer stated ? Link to comment Share on other sites More sharing options...
KRM Posted May 7, 2014 Share Posted May 7, 2014 Nothing really wrong would happen im sure. But the white filter element is supposed to get the particulates and the carbon side takes care of the bad smells in the air Link to comment Share on other sites More sharing options...
