urdrwho Posted May 2, 2014 Share Posted May 2, 2014 I went to look at an engine to dump into my 2.5 engine bay. It was at a subbie seller only used car lot. It is the place I bought my 95 Legacy from several years ago. Anyhow the car is a rust bucket, was traded in last Nov 2013 and they are using it as a parts car. The used car guy sold it to the girl back in 2003. The engine fired right up. It did smoke a bit at first and I was wondering - 1. Car sat for 6 months without starting 2. Leaking valve seals 3. Rings I went in and talked to the guy and he said that ring problems are not normally a subbie problem. Valve stems? Maybe since it was sitting so long. He said go back and let it warm up a bit. The Smokey pretty much disappeared, a quick foot on and off rev and no bluish looking smoke. No CEL came on. The engine is a bit piggy with oil and should have some new valve cover gaskets. The mileage is higher than I had hoped for but it is a 95 out of a Legacy automatic and will dump right into my 97 2.5 bay. Engine oil showed no milky color. Radiator fluid was topped off and a good color. Someone just recently put new belts on the car. He may even have his guys dump it in for $250. So I get out of there with the engine and install for $450. Oh add on the $13 for the rear seal. I'm just not finding any 2.2 engines that are priced in the real world and I'm not sure if I should move forward on this one. One thing I can't handle is a driving smoker down the road. So I need some more opinions on this motor swap. I'm tired of paying insurance on a car that I am not driving. Link to comment Share on other sites More sharing options...
johnegg Posted May 3, 2014 Share Posted May 3, 2014 it depends on how long you plan on driving your car. fix it and sell it , fine. but long term, i would shop a little more. probably not rings, but a wet & dry compression test would tell you. Link to comment Share on other sites More sharing options...
urdrwho Posted May 3, 2014 Author Share Posted May 3, 2014 I don't know how long I'll keep it. I don't plan on having it for my daily driver but if I could squeeze another 20,000 miles out of it...that would be ok. I'd probably drive it 6,000 a year (give or take). I've called all around and nobody has any 2.2 stuff. There is a 2.5 engine with about 100,000 on it but it would might / probably need head gaskets soon and it is a 2.5...the engine I'm running away from. So ya never know how long they will run. http://www.subaruhighmileageclub.com/miles400000.html I mean wow --- "The fellow from Sweden whose picture graces the main page just passed 930,000 km (just over 581,000 miles) on his Outback." http://www.subaruhighmileageclub.com/ it depends on how long you plan on driving your car. fix it and sell it , fine. but long term, i would shop a little more. probably not rings, but a wet & dry compression test would tell you. Link to comment Share on other sites More sharing options...
spooln30 Posted May 3, 2014 Share Posted May 3, 2014 Usually smoke on start up would mean valve seals. Link to comment Share on other sites More sharing options...
johnegg Posted May 3, 2014 Share Posted May 3, 2014 i can not speak to leaking valve seals and how long it would run. but if you keep oil in it it will probably run a really long time. and the seller makes some sense, 200$ for the engine = 20,000 miles, this is a number i can live with. although my best subarus had a per mile price of less than 5 cents. and if it is seals, and smokes only at start up it will probably not embarrass you too much, and likely run several years. and $200 is cheap, back on the road for less than $300, duh!! Link to comment Share on other sites More sharing options...
Bandit240 Posted May 3, 2014 Share Posted May 3, 2014 I'd buy it. I just installed an engine in my car that has almost 300k on the clock. Now I did own the car it came from for the last 2 years, so I'm not worried about it. With the 2.2, I wouldn't have any issues with a higher miles motor. Link to comment Share on other sites More sharing options...
urdrwho Posted May 4, 2014 Author Share Posted May 4, 2014 Before the valve job my 1990 Jaguar would smoke at first start but never again during the day. I don't mind that little puff of smoke in the morning but it is when the smoke puffs after leaving each red light, that is the one I can't handle. I guess I won't known until it is installed. i can not speak to leaking valve seals and how long it would run. but if you keep oil in it it will probably run a really long time. and the seller makes some sense, 200$ for the engine = 20,000 miles, this is a number i can live with. although my best subarus had a per mile price of less than 5 cents. and if it is seals, and smokes only at start up it will probably not embarrass you too much, and likely run several years. and $200 is cheap, back on the road for less than $300, duh!! Link to comment Share on other sites More sharing options...
urdrwho Posted May 4, 2014 Author Share Posted May 4, 2014 On that note I'll probably take the chance. If it doesn't work out I'm probably done messing around with this car. After doing a lot of reading about the 1997 > 2.5 DOHC engines I am amazed at how badly Subaru engineering messed up. I'd buy it. I just installed an engine in my car that has almost 300k on the clock. Now I did own the car it came from for the last 2 years, so I'm not worried about it. With the 2.2, I wouldn't have any issues with a higher miles motor. Link to comment Share on other sites More sharing options...
