fuzzyglock Posted April 16, 2014 Share Posted April 16, 2014 Hey guys, I've been having problems lately with code p2096, my car is totally stock. I looked at my learningview and concluded that I must be running really lean at low RPM's, which should suggest an intake leak, correct? In any case, I know I've got more going on on that table than I understand, and was hoping you fellas could help me interpret. I also included a log, not sure if that is gonna be helpful in this situation.romraiderlog_acc_20140413_184823.csv Link to comment Share on other sites More sharing options...
JermTheElf Posted April 16, 2014 Share Posted April 16, 2014 It seems you may have a pre turbo leak. It's adding fuel in that initial (+11) category. Typically you want to see under +/- 5 here. That may be causing the pulled timing in the large grid. Link to comment Share on other sites More sharing options...
