shiby Posted April 15, 2014 Share Posted April 15, 2014 So I order a whiteline RSB for 05 legacy gt and it came in today.... yay:confused: I looked at packing slip and part number is BSR49XZ... from what im finding this is for 08+ WRX and 09+ Legacy Seems as though whiteline bar I'm looking for would be BSR39Z ... this is a 20mm and not a 22mm like the BSR49XZ i currently have I'm pretty sure i was sent the wrong kind of bar and this will not fit? Has anyone used this bar and it worked, or should i contact and see about getting BSR39Z instead even thought its a bit smaller? Link to comment Share on other sites More sharing options...
AZP Installs Posted April 16, 2014 Share Posted April 16, 2014 So I order a whiteline RSB for 05 legacy gt and it came in today.... yay:confused: I looked at packing slip and part number is BSR49XZ... from what im finding this is for 08+ WRX and 09+ Legacy Seems as though whiteline bar I'm looking for would be BSR39Z ... this is a 20mm and not a 22mm like the BSR49XZ i currently have I'm pretty sure i was sent the wrong kind of bar and this will not fit? Has anyone used this bar and it worked, or should i contact and see about getting BSR39Z instead even thought its a bit smaller? Where did you buy it from? -Mike Paisan http://www.pbase.com/paisan/image/153798190.jpg Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
shiby Posted April 16, 2014 Author Share Posted April 16, 2014 Autocityimports Sent an email and currently waiting to hear back Link to comment Share on other sites More sharing options...
AZP Installs Posted April 16, 2014 Share Posted April 16, 2014 Autocityimports Sent an email and currently waiting to hear back I'm sure they can help out with the proper part numbers, unless of course they are typical pump and dump shop where they put things in their catalog based on what they have in paperwork rather than first hand knowledge of the products. -mike Link to comment Share on other sites More sharing options...
gmentals Posted May 21, 2014 Share Posted May 21, 2014 Did you ever get the right bar? I'm looking for a rear 22 mm adjustable and can't find any. Link to comment Share on other sites More sharing options...
shiby Posted May 25, 2014 Author Share Posted May 25, 2014 Did you ever get the right bar? I'm looking for a rear 22 mm adjustable and can't find any. yes, contacted the vendor and got the correct parts without any issue BSR39Z was the correct part# .. its a 20mm adjustable from what i found atleast whiteline only goes up to 20mm on RSB for an 05 LGT ... newer models they go up to 22mm Link to comment Share on other sites More sharing options...
AZP Installs Posted May 26, 2014 Share Posted May 26, 2014 yes, contacted the vendor and got the correct parts without any issue BSR39Z was the correct part# .. its a 20mm adjustable from what i found atleast whiteline only goes up to 20mm on RSB for an 05 LGT ... newer models they go up to 22mm New models 2010+ can use any sways in the rear as the 08+ STi ones, they come in sizes up to 27mm IIRC. -Mike Paisan http://www.pbase.com/paisan/image/153798190.jpg Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
