johnegg Posted April 16, 2014 Share Posted April 16, 2014 i have a hard 1-2 shift in my 97 GT. it came that way when i bought w/125k and a bad engine. i swapped in a 96 ej22. i have disconnected the dropping resistor, swapped in the one from my outback, change the ATF, added trans-x, removed trans-x, swapped the TCU, twice, run seafoam through the intake, and still it jerks, 1-2. it seems to be worse with no load, or when cold. less noticeable when warm or under load. i did read one thread where the problem started right after an AFT ''flush'' at a shop. they fixed it by replacing the valve body in the trans. this seems extreme to me , but if it worked,..... so god luck. i hope you find the solution and then post it. Link to comment Share on other sites More sharing options...
boattlebot Posted April 18, 2014 Share Posted April 18, 2014 Im gettin around 13-15 mpg highway I need to improve it. I seafoamed and tune up maby makin my ej22 breath better? Ideas most defently welcome on my situation Link to comment Share on other sites More sharing options...
Stevo F Posted April 18, 2014 Share Posted April 18, 2014 Im gettin around 13-15 mpg highway I need to improve it. I seafoamed and tune up maby makin my ej22 breath better? Ideas most defently welcome on my situation Wow, that doesn't sound like a very happy EJ22 Link to comment Share on other sites More sharing options...
sunny5280 Posted April 18, 2014 Share Posted April 18, 2014 Im gettin around 13-15 mpg highway I need to improve it. I seafoamed and tune up maby makin my ej22 breath better? Ideas most defently welcome on my situation Take off the parking brake before driving? In all seriousness though with such little information it's difficult to provide a meaningful suggestion. And driveability issues? Link to comment Share on other sites More sharing options...
boattlebot Posted April 19, 2014 Share Posted April 19, 2014 She runs great no check engines everythings fine as far as I can tell. No drivabilty problums shifts normal runs about 2800-3200 crusing at around 65 70 Link to comment Share on other sites More sharing options...
