Yamba6 Posted April 6, 2014 Share Posted April 6, 2014 I know our stock exhaust comes with a tension setup for the center pipe to cat. I'm told its a hardware kit, bolt with built in spacer followed with a spring and nut. The borla kit came with just screws, washers, nuts.... this doesn't allow for torque flex to take place at that point like it was designed with stock setup. Now my car is bone stock so I a not creating any excessive power to which I'm for sure going to need that. Is this something I should have concern about or will it be fine if I just use the hardware from borla? Link to comment Share on other sites More sharing options...
lingling1337 Posted April 6, 2014 Share Posted April 6, 2014 I just use long bolts with b washers and nuts. Never had a problem. Link to comment Share on other sites More sharing options...
Yamba6 Posted April 7, 2014 Author Share Posted April 7, 2014 This can be closed. It didnt matter after all. My oem exhaust was so froze up to the gasket and cat that it acted as if it wasnt on springs anyways. lol Link to comment Share on other sites More sharing options...
