killzone Posted April 3, 2014 Share Posted April 3, 2014 1 leaking front sun roof , can you buy replacement seals and were. 2 Rust bubbles on the two front doors under the mirrors , sand paper job or weld in new metal. And a. Any one recommend good rust proofing for behind the door panels. Thanks. Link to comment Share on other sites More sharing options...
johnegg Posted April 4, 2014 Share Posted April 4, 2014 rust is not my area of expertise. but the sunroof, usually it is caused by the drains in the roof / ceiling being clogged. open the sun roof and stick your head up through the hole. look for crap, leaves, junk, in the 2 front corners. there is a gutter system that catches the water, and drain holes that take it away. check the drain holes. another possibility is the plastic tubing in the A pillar that connects to the drain holes, if it disconnect from the plastic gutter tray, the water will leak into the car, but not drip from the ceiling. i park in front of my house under a maple tree. and i have to clean my drain holes about twice a year. i should probably do it more often. but the wet driver seat is a dead give away that the drains are plugged. good luck. Link to comment Share on other sites More sharing options...
Stevo F Posted April 4, 2014 Share Posted April 4, 2014 That's on odd place for rust on the doors. If it was rusting through, it usually starts at the bottom. Perhaps it's just surface rust under the paint that just needs to be ground down. I would see if it's weak. If it is rusted through, you could make a patch from scrap metal, cut out the bad metal with a Dremel tool, and you could weld (or pop rivet) a the new metal over it). I've done a lot of metal patching over the years and much of it lasted a long time. I next have to do the two small (for now) sports behind the rear fender opening on the Impreza we just bought (from Pennsylvania). Link to comment Share on other sites More sharing options...
boattlebot Posted April 4, 2014 Share Posted April 4, 2014 Yea ima have to get good at patching myself if unless I start buying really new cars. Theey rust good up here. Got lucky on my leggy no rust really. But a short tearm to keep the rust from spreadin to much before u can really work it out, just take some clear rustoloiem. Dont look pretty but from my experiance helps stop it spreadin for a while Link to comment Share on other sites More sharing options...
spooln30 Posted April 4, 2014 Share Posted April 4, 2014 The only way to stop rust from spreading is to remove it otherwise it will just come back in time. Link to comment Share on other sites More sharing options...
