aguyinthesky Posted March 29, 2014 Share Posted March 29, 2014 Ok, goin turbo. Ive collected most pieces and components i need. I know 1st gen legacy ss crossmembers are direct bolt ons. Is there any modification needed or what is involved for a 04 sti or 06 wrx crossmember? I hv a 97 lgt Link to comment Share on other sites More sharing options...
aguyinthesky Posted March 29, 2014 Author Share Posted March 29, 2014 36 people viewed and nobody knows?? Link to comment Share on other sites More sharing options...
lockmedic Posted March 29, 2014 Share Posted March 29, 2014 Chill Beavis. Crossmember swappin' ain't something most people do for fun. I'm not "most people" and I can't definitively answer that question. . . but I can tell you when you get to 2nd gen chassis you can go all the way up to 2009. . . and you can use an Impreza crossmember but if it's from an STi or Saab 9-2x, the mounting points for the lower control arms are wider than the Legacy control arm bushings, so you'll need to either run STi control arms ($$$) or use washers as spacers (which is what I did). My info is relative to 2000+ but I'd be very surprised if it didn't hold true for 95-99 as well. http://legacygt.com/forums/showthread.php/study-turbo-crossmembers-and-steering-racks-221606.html?t=221606&highlight=crossmember Link to comment Share on other sites More sharing options...
spooln30 Posted March 30, 2014 Share Posted March 30, 2014 Direct bolt in. Link to comment Share on other sites More sharing options...
