bloodwingg2 Posted March 29, 2014 Share Posted March 29, 2014 Hi guys, I bought the hid kit from hidextra and got installed yesterday but at night I noticed that the hid bulb on driver's side going bad. The next day, when I want to drive, I noticed that the bulb on passenger's side also went off. Tried to change another bulbs and also turns off. Do I get the defective ballast ? One more thing, when i change the bulb, do I need to disconnect the battery ? Any suggestion would be appreciated Link to comment Share on other sites More sharing options...
rice_rocket Posted March 29, 2014 Share Posted March 29, 2014 No..no..maybe.. did you disable daytime running lights? Link to comment Share on other sites More sharing options...
bloodwingg2 Posted March 29, 2014 Author Share Posted March 29, 2014 I did not disable the daytime running lights. It turns on automatically Link to comment Share on other sites More sharing options...
rice_rocket Posted March 29, 2014 Share Posted March 29, 2014 Do a search about the drl and hid..they don't mix. I don't have a 2014 so I don't know how to disable them... but that's your problem most likely. Link to comment Share on other sites More sharing options...
Claw Posted March 31, 2014 Share Posted March 31, 2014 just leave your headlights on. reason being, the 05-09 uses the low beams as DRLs, so it supplies significantly less power that's required to fully ignite the low beams. Leaving the headlights on all the time will stop that from happening. not sure if that's applicable to the new model years, but check anyways. Or do the DRL disable mod. Search the forums for more info. Link to comment Share on other sites More sharing options...
bloodwingg2 Posted April 14, 2014 Author Share Posted April 14, 2014 I realized that I did not using relay that included from the hid kit. Is it necessary to use the relay and connecting it to both ballasts ? Link to comment Share on other sites More sharing options...
