MAP Posted March 25, 2014 Share Posted March 25, 2014 I can't seem to find a clear answer to this, some posts say 20mm others say 21 mm. I was hoping to have the bushings on hand so I could replace them when I changed the oil this weekend. Unfortunately there's no easy access to the bar without lifting the front of the car and removing the plastic cover underneath. And anyone have part numbers for polyurethane bushings, whiteline or avo or other that will fit the stock brackets? 4 months ago I discovered that the parts rockauto was listing for the GT are wrong. They have the curved top surface that is common for brackets on previous generation legacys. Our brackets are flat. I shaved the bushings as best I could to make them work but was not happy with the result. Any suggestions would be appreciated. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted March 25, 2014 Share Posted March 25, 2014 I could be wrong, but I'm pretty sure it's 21mm. Honestly though, 1mm shouldn't make a difference, either one should fit the bar. Link to comment Share on other sites More sharing options...
Zac88 Posted March 25, 2014 Share Posted March 25, 2014 its 21mm Link to comment Share on other sites More sharing options...
