boattlebot Posted March 19, 2014 Share Posted March 19, 2014 did the 2nd gens have a keyless entry option? or would i have to go aftermarket or retrofit a later system? i lock my car and id like a keyfob to lock it up for me cus im just lazy i guesse Link to comment Share on other sites More sharing options...
mailman Posted March 19, 2014 Share Posted March 19, 2014 I think so, but idk if they are "prewired" for it or not. I read about someone putting one into a first gen and there was plenty of room for the motor and whatnot. Link to comment Share on other sites More sharing options...
mailman Posted March 19, 2014 Share Posted March 19, 2014 http://sl-i.net/FORUM/viewtopic.php?f=39&t=25316 Link to comment Share on other sites More sharing options...
boattlebot Posted March 19, 2014 Author Share Posted March 19, 2014 sweeeeeeeeeeeeeeeeeeeeeeeeeet Link to comment Share on other sites More sharing options...
SockMonkey Posted March 19, 2014 Share Posted March 19, 2014 I didn't install it but I have the UNGO MS1001 keyless entry/alarm. It pops the trunk, locks & unlocks, and has an alarm that goes off, if say a door is opened after its locked&alarmed. It also is supposed to have a shock sensor, though I haven't tested that. Â I'm happy with it and just picked up a complete spare system on ebay for under $15, though I really only bought it for the extra key fobs. (should note that last one I saw on eBay sold for maybe $50, I just got lucky with this one) Link to comment Share on other sites More sharing options...
PorkchopSandwiches Posted March 19, 2014 Share Posted March 19, 2014 It wasn't factory per se. It was a dealer installed option. Up through '98 used "code alarm" keyless entry systems. I have the manuals and installation guide for it. I don't have a scanner, but if you need some info I can snap some pictures of it and upload it. FWIW, you can use keyfobs from a bunch of different makes since the code alarm system was a dealer option for a bunch of different cars. Link to comment Share on other sites More sharing options...
boattlebot Posted March 20, 2014 Author Share Posted March 20, 2014 in theory i only need to rig it to my drivers door. i dont know if it changed in later years but on my 96 my power lock switch is the lock itself if i lock my drivers door they all lock and vise versa. it also locks/unlocks the trunk (even tho it sticks back thier every now and then). so if i can get it so my drivers door it operated by a key fob it should lock/unlock all of the doors. so any ideas how to get started on this little project of nothing but convenience and laziness? Link to comment Share on other sites More sharing options...
PorkchopSandwiches Posted March 20, 2014 Share Posted March 20, 2014 Find a car at the junk yard and take a door and all that modules under the dash? Do you have power locks but just no keyless? If not I guess you'd need the whole door panel with the button on it. Link to comment Share on other sites More sharing options...
boattlebot Posted March 20, 2014 Author Share Posted March 20, 2014 the 96 had no button for it (to my understanding) my power locks work in that when i manualy operate my drivers door lock, the others will lock or unlock acordingly. so in my mind if i can physicly move the drivers door lock with an actuator controled by a key fob, the other locks will (should) move acordingly just as if i was operating my drivers door lock by hand or key Link to comment Share on other sites More sharing options...
twisty Posted March 24, 2014 Share Posted March 24, 2014 it seems like it would be easy enough to get the actuator from a passenger side door, then fit it to your driver door and make it trigger the lock mechanism. im planning this same thing when i install my alarm in a few weeks, ill let you know if you havent already done it. Link to comment Share on other sites More sharing options...
Headtrauma89 Posted March 24, 2014 Share Posted March 24, 2014 Check under the dash. It may already be there. Every legacy I've had (except my L) was already set up with it, they just didn't have key fobs. Link to comment Share on other sites More sharing options...
boattlebot Posted March 24, 2014 Author Share Posted March 24, 2014 my legy is an L modle tho so i probly dont have it. im slowly upgrading it to a lgt Link to comment Share on other sites More sharing options...
