Derrickmd30 Posted March 11, 2014 Share Posted March 11, 2014 have a subaru legacy and it only has front speakers. I wanted to know are they prewired for rear speakers and where do you'll put them at? do you'll cut out the rear door panel and put them in or do you'll just mount two speaker boxes in the rear wagon? also do the DIN stereo fit perfect in the car because i can't find a kit anywhere? Link to comment Share on other sites More sharing options...
Stevo F Posted March 12, 2014 Share Posted March 12, 2014 The wagon had the rear speakers in the rear doors and the sedan had then in the rear package tray shelf. I would have thought all Legacy's had 4 speakers from the factory, but maybe not. A standard single DIN stereo should fit right in place of the original stereo and a Double DIN should fit as well (but I've never tried it). I had to trim the outer trim piece with my Dremel tool was all of the mods I did. Also get a an plug that plugs into the original Subaru wiring plug- very simple wiring and install. Link to comment Share on other sites More sharing options...
Bassnectar Posted March 12, 2014 Share Posted March 12, 2014 go to the junkyard and take the rear speaker trim. then take your trim off where to cut is marked on the panel so it's not that hard to put rear door speakers and make them look stock into any 2nd gen Sent from my SGH-I337M using Tapatalk Link to comment Share on other sites More sharing options...
Bassnectar Posted March 12, 2014 Share Posted March 12, 2014 go to the junkyard and take the rear speaker trim. then take your trim off where to cut is marked on the panel so it's not that hard to put rear door speakers and make them look stock into any 2nd gen. check your stereo harness it's possible they are pre wired that's the easiest place to find out. compare your harness to a labelled color schematic to verify of rear speaker wires exist on yours if so hopefully they can be found at the door Link to comment Share on other sites More sharing options...
mailman Posted March 12, 2014 Share Posted March 12, 2014 My wagon has only two front door speakers. Did any 2nd gens have the rear strut speakers like the first gens? Link to comment Share on other sites More sharing options...
Stang70Fastback Posted March 12, 2014 Share Posted March 12, 2014 My wagon has only two front door speakers. Did any 2nd gens have the rear strut speakers like the first gens? The only speaker configurations at the rear were one in each rear door in the wagons, or two on the rear shelf in the sedans. Also, if your wagon was awesome, like mine, you got two tweeters on the D pillars. I'm assuming the sedans would get a coaxial setup, or tweeters on the C pillars or something. Link to comment Share on other sites More sharing options...
DGR81 Posted March 12, 2014 Share Posted March 12, 2014 It was a pain in the ass to do the rear speakers in my sedan. Had to pull out the whole back seat and the rear shelf carpet than you had barely any room to unbolt them. Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted March 14, 2014 Share Posted March 14, 2014 The only speaker configurations at the rear were one in each rear door in the wagons, or two on the rear shelf in the sedans. Also, if your wagon was awesome, like mine, you got two tweeters on the D pillars. I'm assuming the sedans would get a coaxial setup, or tweeters on the C pillars or something. The sedans did not come with rear tweeters in the C pillar. You totally have to add them in if you are thinking about upgrading sound. Link to comment Share on other sites More sharing options...
