jaboyjay Posted February 28, 2014 Share Posted February 28, 2014 So I replaced my exhaust manifold today in the freezing cold. But when I took the nuts off the studs or "attempted" the studs came out of the head. Does anyone have a part number? or a store they picked some studs up at? I don't wanna leave it the way it is It's a 3Rd gen legacy gt limited 2.5l if that maters Link to comment Share on other sites More sharing options...
FJuan Posted February 28, 2014 Share Posted February 28, 2014 Is the stud damaged? If the original stud is still good, just re-use it. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Nubie Posted February 28, 2014 Share Posted February 28, 2014 Yea as long as the (insert British pronunciation) aluminum threads are ok, just use it, it should still tighten up. It will make install a little easier anyway. Link to comment Share on other sites More sharing options...
jaboyjay Posted February 28, 2014 Author Share Posted February 28, 2014 The threads aren't damaged but I am missing one. and one doesn't seem to be tightening almost like it's stripped but the threads weren't damaged unless it was the head itself? Link to comment Share on other sites More sharing options...
FJuan Posted February 28, 2014 Share Posted February 28, 2014 Take one of the studs to an auto part store, they should be able to match it up. I would recommend re-tapping the threads inside the heads to make sure nothing is stripped inside. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
