SubruMaster Posted February 22, 2014 Share Posted February 22, 2014 Hi, I have a Subaru outback BG9 which is giving me hell.The ignition coil is producing sparks on 1-2 but 3-4 has nothing!The ignition coil and igniter have been replaced but the problem is still there!Another thing is when i connect the green test cables under the steering wheel,a code is being generated....31 which is throttle sensor and i has been tested to be ok!What could be the problem? Link to comment Share on other sites More sharing options...
johnegg Posted February 22, 2014 Share Posted February 22, 2014 the 97 is obd2 and you cannot blink the codes with the test connectors. drive to a parts store and they will read the code for free. the coil or igniter are the likely cause if the miss fire, if it is front vs. rear as you say. if you are 100% sure the replacements are in good working order i would look for wire damage. you can test the coil, resistance i think, but i don't know the details. are you sure it is a spark problem.? can you get it to start. they run pretty good on 3 cylinders, not sure about 2. have the codes read. Link to comment Share on other sites More sharing options...
JJay03 Posted February 22, 2014 Share Posted February 22, 2014 I would check the codes also and report back. Link to comment Share on other sites More sharing options...
SubruMaster Posted February 26, 2014 Author Share Posted February 26, 2014 Thanx guys...i faulted only to find the ECU faulty..there is an IC PA1558H which has a massive crack tht could either hv been caused by poor earthing or short circuit. Link to comment Share on other sites More sharing options...
