upshiftn Posted February 26, 2014 Author Share Posted February 26, 2014 okay. the resistor was in place underneath the electrical tape and nothing seemed to be compromised so it seems a little odd I got the P0546 code in the first place which went away after the 4th engine start. we'll see how the new one goes with a long drive ahead tomorr. Link to comment Share on other sites More sharing options...
upshiftn Posted March 15, 2014 Author Share Posted March 15, 2014 update from compression test: results: cylinders 1 thru 4... 121, 120, 121, 120. pretty normal for 92k miles. no valve adjustment needed however a lazy injector will most likely be the cause but may need to wait for a CEL to determine which one. Link to comment Share on other sites More sharing options...
Cptxbig Posted March 15, 2014 Share Posted March 15, 2014 I'm hoping my problem is something simple as well is have the same problem with rough idle and it threw a cel for cyl 4 but I had the plugs and coils done ocv intake manifold gasket only thing I can do now is compression/leak down it hope that's normal and that it's just a injector Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
