lovedr79 Posted February 12, 2014 Share Posted February 12, 2014 First Subaru clutch done. 2005 gt. Sachs clutch. How long is this new clutch going to smoke for? Drives great. No slippage, engages fine. Shifts fine. But smokes...... Link to comment Share on other sites More sharing options...
Brian3676 Posted February 12, 2014 Share Posted February 12, 2014 I have never had a brand new clutch smoke.... Did you make sure the flywheel, disk and pressure plate was clean? The smoke smells like clutch or ? Link to comment Share on other sites More sharing options...
lovedr79 Posted February 12, 2014 Author Share Posted February 12, 2014 Smells like clutch but could be spilled tranny fluid, I spilled more than a little. Link to comment Share on other sites More sharing options...
iNVAR Posted February 12, 2014 Share Posted February 12, 2014 You need to clean off the fluid with some sort of solvent. Carb/brake cleaner spray to remove it and then hose off the area. Then it should burn off quickly. Clutch should not be smoking, period. Link to comment Share on other sites More sharing options...
lovedr79 Posted February 12, 2014 Author Share Posted February 12, 2014 i didnt think the clutch should smoke as i have done them on other vehicles, but i know sube's have a stinky clutch issue. it doesnt smell like burning clutch. Link to comment Share on other sites More sharing options...
lovedr79 Posted February 15, 2014 Author Share Posted February 15, 2014 well i am an IDIOT! figured out why it was "smoking" then night i finished it up it was about 10 degrees outside, lots of exhaust steam. well i pulled the intercooler off today sprayed everything i could with brake cleaner wiped what i could off. started it up let it warm completely up i have a leaking down pipe gasket where it meets the exhaust pipe....... it did have a slight clutch stink but was not as bad as the first time i drove it after i put the new clutch in. Link to comment Share on other sites More sharing options...
