Help with wheel figment
tDoug60
Posted
Just pick these up today from my uncle.
They are 17x9.5 +56 sawblade current wrap in 275/40.
I planned on running 230/235/40 any suggestion on which tire size to go with.
and got adaptors
http://www.amazon.com/gp/other/aw/d/B00HQSQH8S?cache=2cd3fa2c2bd006df5c704954bd4e5165#ref=mp_s_a_1_2&qid=1391377203&sr=8-2&precache=1
http://mywheeladapters.com/5x100-to-5x475-5x100-to-5x1207-Wheel-Adapters-Rim-Lug-1-Billet-4-Spacers-P3240015.aspx
Trying get these on the car ASAP. Any help would be nice
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Posted
Be real careful with these things - they loosen up after installing - check them often - also remember your offset has changed so the wider the tire the closer to the quarter panel or fender you will be by the thickness of that adaptor
Posted
I'm trying to figure out what my offset will be with these.
Also plan on installing camber kit
Posted
you're gonna need a massive fender pull to fit these along with at least -3deg or more of camber. That gonna put a lot of stress on the wheels bearings which will only be exacerbated by those 1" spacers.
Posted
I can't find smaller adaptors
I may go with a 215/225 215 is extreme but I don't plan on runing these wheels year round
Edit- just found a Adaptec 19mm thickness
Posted
You bought a labor of love. I'd pre-order a set of wheel bearings, too. Expect to spend considerable effort getting these to fit and work well on your car. The extreme width and offset are not going to help you. Running a smaller width tire is not going to help either. A 9.5 rim would take a 235, however, the 275 would be a better fit (which is why Chevy fitted one on there)
Posted
I've seen ppl stretch a 205 on a 9.5 lol so to me 225 isn't a major stretch just found a 15mm adaptor instead of 1"
  • 2 weeks later...
Posted
Sold the wheels for 200+ profit.
Still looking for 17x9/9.5
Anything that will fit without to many mods
Posted
these two sentences don't belong together
maybe a 9+42 wheel with no more than 235 width tire and non-low ride height
Posted
The car isn't drop and I don't plan to drop it. I can only find stuff in +36 for 17x9
what do you need for a offset? i found +38 drag dr-31/38's +42 xxr 522's rota also has et 42 rims
not the greatest brands but still options.
Posted
I was actually looking at the xxr wheels they are one. But everything I want is to high or way to low.
I'm just trying to find a correct wheel that will fit
These str are +22 :-$
Posted
http://www.willtheyfit.com/index.php?width=205&aspect=55&diameter=15&wheelwidth=6&offset=55&width2=275&aspect2=40&diameter2=16&wheelwidth2=7.5&offset2=48#content
this will help you calculate what exactly you need for offset and how much its going to poke and how much closer its going to be to the struts. you just gota know the dimentions of your wheel wells.
enkei tsp6 17x9 et45 enkei jenjin et45 TS6 et 45 Kojin et 45
