R180 hubs
knockoutgiant
Posted
I'm assuming your looking a GD stuff?
No they won't fit.
Find a BL/BP with an R180 rear and look at that set-up (still 5 x 100 hub's thou) - trailing arm's will bolt in with the exception of a different size hole for the ABS sensor.
Posted
There was a set of brembo's for sale with R180 hubs from a Version 7 STI, I've since got the answer that I can't fit any of them, instead I've found someone that has a whole set, front and rear brembo's and caliper adapters that will bolt stright up, so looks like I'm going to go with that.
