sounder Posted January 10, 2014 Share Posted January 10, 2014 so i looked around for this anwser but could not find it, im not really the biggest person to know about cars, so i need some help. i have a 09 L 2.5GT and can see the duel exhaust in the back, i have never lifted the car myself and was wondering if it really is two pipes? or is it one pipe that splits into two pipes, does it make a difference. and what im getting to is noise , i dont have any subbie rummble or anything, it is stock , but i would like to know how to change that without spending a arm and a leg:spin: Link to comment Share on other sites More sharing options...
RWebb Posted January 10, 2014 Share Posted January 10, 2014 No single pipe -> duel mufflers... for looks. Link to comment Share on other sites More sharing options...
Berzerklo Posted January 10, 2014 Share Posted January 10, 2014 http://legacygt.com/forums/showthread.php/new-hog-zawst-system-sound-power-patented-washer-technology-35764.html The cheapest option is nicknamed the hogzawst. Basically you replace the last exhaust gasket between the muffler and the exhaust tips with 1-3 washers on each bolt. SO it is essentially an exhaust leak but it costs under $5. I have been running this for a year or so now, but only have 1 washer on each bolt so it is pretty mellow but at least I can hear my engine. I have heard it gets pretty loud if you put in more washers - check out YouTube. The next step up is the Nameless Performance Muffler Deletes. You replace your mufflers with a nice stainless steel pipe but still costs a few hundred dollars. BTW - Welcome to the boards! Link to comment Share on other sites More sharing options...
sounder Posted January 10, 2014 Author Share Posted January 10, 2014 thanks Berzerklo i will look into the video . and i love the boards and what does he mean by No single pipe -> duel mufflers... for looks?? and berzerklo whats the difference with spec-b and GT ? Link to comment Share on other sites More sharing options...
ras06LGT Posted January 12, 2014 Share Posted January 12, 2014 There is a single pipe running from the turbo to the axle, at which point it splits off with a y-pipe to the dual mufflers. It's for looks, not performance. I opted for the muffler delete option to get a bit more noise from my GT. I elected to build my own, and only ended up costing me around $40 in supplier and an afternoon of welding. Gives a great rumble and is surprisingly civil around town (until you floor it - then it screams). The Spec-B gets a six speed trans, Bilstein suspension, color accented interior, and different wheels. Pretty much everything else is the same as the GT. Link to comment Share on other sites More sharing options...
